This command configures a local IPv4 address to be used as SIP for encapsulated packets.
| ipaddress | Configure the IP address to be used as source IP address for VXLAN packets encapsulated by this gateway. |
| ipaddress | An existing interface IPv4 address. |
| vr | VR/VRF instance the IPv4 address is configured on. |
| vr_name | An existing VR/VRF name. |
| none | Remove existing IP address configuration for the local tunnel endpoint for this virtual router. |
The address must have been configured as an interface address prior to issuing this command. Although not mandatory, it is strongly recommended that a loopback VLAN IP address be used as the local IP address for tunnels. “VR-Default” is the default for VR/VRF name. ExtremeXOS checks if the given IP address is configured on the VR/VRF. If not configured, the command fails with an appropriate error message. This release of ExtremeXOS supports tunnel termination on a single VR/VRF. That VR/VRF can be a user created. If you intend to change the IP address or the VR/VRF, you can re-issue the same command with a different IP address to effect the change.
To configure a local tunnel endpoint IP address in a user created VR/VRF:
configure virtual-network local-endpoint ipaddress 10.10.10.1 vr VR-User
To change a local tunnel endpoint to a different IP address within the same VR/VRF:
configure virtual-network local-endpoint ipaddress 20.20.20.1 vr VR-User
To unconfigure a local tunnel endpoint IP address:
configure virtual-network local-endpoint none
To change a local tunnel endpoint to a different IP address in a different VR/VRF:
configure virtual-network local-endpoint ipaddress 10.10.10.1 vr VR-Default
This command was first available in ExtremeXOS 21.1.
This command is available on all Universal switches and stacks supported in this document.
